Loading or Importing of Creo Elements Direct Modeling files into Creo Parametric through Windchill.
While in Creo Parametric and Windchill Creo Elements Direct Model files can be viewed but cannot be imported directly into Creo Parametric, although this functionality in there if the Creo Elements Direct files are not loaded into Windchill.
This functionality needs to be added to so the files can be loaded directly into Creo from Windchill, exporting the files out to the operating system folders and then opening it up in Creo is adding more steps to the process and also this creates uncontrolled documentation as you have taken it outside of the controlled system to utilize.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
