1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
The company I work for Automotive industry. My role can be described as an internal IT consultant. Approx. 2000 users from configuration management, engineering to production are using Windchill.
2. What version of Windchill are you currently running?
11.2.1.10
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
When a user applies an option filter to a structure there should be a loading symbol all the time or the view should be kind of blocked until the filter is applied. Actually there is a symbol appearing in the upper right but it takes up to one minute till this symbol appears. So when clicking on a predefined option filter and nothing happens the user gets confused, reloads window or applies option filter twice. See attached video.
4. What is the use case for your organization?
