The log generated when you remove the unreferenced task queue creates a line for each treated entry and a summary at the end of the treatement, all at INFO verbosity level, the entry lines should be logged at DEBUG level, since the queue may contain thousands of entries and this will encumber the log file uselessly.
And we can't disable the info level logging because then the summary line won't be written to the log and it is the most relevant information.
