MAPSB: Multi select in Visualization using “box” does not select rows in structure. Hard for user to pick part by part with Ctrl+Mouse, much quicker to ”box” parts.
Have encountered similar problems during M-BoM build in MAPSB and had it reported to PTC.
Solution provided was to use the best practice approach of select the items/components in the Design View Visualization Pane and then click COPY icon and then assign the copied items/components to necessary operation on the Manufacturing View Pane.Regards...!!!
Thanks a lot for your input. We have delivered this feature. In order for this to work, you need to enable Custom selection as shown below. Then you should be able to multi-select as you have requested.
JC
