The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
MPMLink : Make or Buy: ability to disable (or "smart" remove) part usage link in the mBOM
Business use case:
-in the eBOM (can be inherit and build from CAD assembly), the engineering deparment will design each single parts and assemblies.
-in the mBOM, manufacturing engineers will delete sub parts of purchased assemblies , cause in the mBOM (and by extension in the ERP), we do not need the sub parts details ... as we never buy or built these single sub parts ...
example for a ball-bearing : all is design in eBOM (ball + casing = bearing.asm) but in mBOM, only bearing
This use case cause the equivalence reports to show differences between eBom and mBOM:
we can not identify "real" difference : ie if engineering department remove or add a new manufactured component
from non significative differences .. a purchased assembly sub component removed by manufacturing department
MPMLink should permit to "disable" some usage link in the mBOM, and all downstream applications should take care of this:
- equivalence reports
- BOM filter ConfigSpec
- Creo View Visu (this use case make the purchased assembly not visible in CreoView (dynamic view in PSB or in MPM Process Plan explorer) Make or buy to be taking in account in order to display correctly structure in CreoView when leaf level isn't managed as article (see SUMA impact ?)
- ESI to send the mBOM without purchased sub levels to ERP
2 Comments
GregoryPERASSO
the PView issue is described in this case (same issue in manufacturing or service BOM explorer)
https://www.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS102474
it is a typical use case in xBOM management to remove some sub parts or sub assemblies
- In mbom, for purchased assemblies (we do not want to see and order the single sub parts)
- In sbom, for sub parts that we do not want to maintain or repair (replace only the parent asm ...)
CreoView should open the represenation of the leaf nodes , regarding the WTpart configspec filter, even if it is an assembly in the upstream View
PTCModerator
Emeritus
