Option and Attribute filter exists for filtering on product but not on process when using Edit Filter.
There is a need or business case to filter on option and attribute also in a process plan, this to only show the operations that are valid for a specific variant (not needed to be a complete product). Using part tags are not enough
link to case, spr, article
https://support.ptc.com/apps/case_logger_viewer/auth/ssl/case=12250990
