MPMLink : ability to sum quantities when having same WTpart number under same level
During the process of transformation of Engineering BOM to Manufacturing BOM  (or Customer service BOM)
There's some case where same WTpart number can be add several time under the same level
add an action in MPMLink to automatically sum this quantities under one BOM link ...
The opposite function already exists OOTB to split quantities into several BOM links
2 Comments
jgriffin-2
1-Newbie
This would be especially helpful for those of us integrating into Oracle 11i which has limitations, not allowing multiple occurrences of a part within an operation.
I would also add that the ability to copy/paste the comments from within the Manufacturing Product Structure Explorer -> Uses tab on the mBOM would be equally helpful for when needing to split occurrences so that the comments are easily split also.
PTCModerator
Emeritus
Status changed to: Archived
