Currently,
only 3D Annotations created in Creo, if designated, can be make selectable for Downstream (e.g. create control characteristics using the annotation).
The current limitation is not allowing the use of the digital information in the MPMLink Work Instructions.
Would be awesome if PTC could enable this functionality, make Windchill CAD indipendent even for MPMLink.
