Make ProjectLink Library Aware
We want to explore ProjectLink to be kindof a Common Workspace (perhaps a Multi-User Workspace function would be a much better idea instead - LOL). I want to be able to use Product/Library stuff in my Project Workspace without having to deal with the problems that having to 'share it brings'. Perhaps a sort of Global Pass function could be assigned to a project so that it can use content from Container X, Y without having to do the share stuff. Anyway we go to the trouble of nicely setting up libraries and the like and then bam the Project mentality takes over and mass pain results. First you have to change a preference to enable auto-matic sharing (otherwise the process of adding a bolt to your assembly becomes mind numbingly long). Then the content from the library ends up dumped into the default folder. Totally irritating make work stuff. Perhaps we're using the tool completely wrong (let me know) but it seems to add a lot of steps and the project folders end up a total mess.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
