Only few attributes are available to drive the number and name of the Illustration Source generated with com.ptc.wvs.server.publish.EPMPostPublishDelegate
So far (and if I'm not wrong) only attributes relative to the CAD document are available:
{AUTHORING_APP}, {EPM_NAME}, {EPM_NUMBER}, {EPM_TYPE}.
What I've in mind is to be able to use the attributes from the WTPart.
But if the attributes from the viewable are also available, this would be great.
