Make database index without reference to schema name
Some Windchill database indexes have a hard-coded variable to the schema name where they are instantiated. This is causing issues when doing rehost.
To avoid the hassle of manually recreating the index after a rehost it would be good if the hard-coded reference to the schema name could be removed.
This enhancement is based on the Technical support case
https://support.ptc.com/apps/case_logger_viewer/auth/ssl/case=13389725
1 Comment
olivierlp
Community Manager
Status changed to: Archived
