Hi
We use the Windchill Desktop Integration without Office integration and then there is no Check Out message when you open a file.
The issue we see now is that people update documents from DTI without checking them out first - they can edit them and save them - but it is saved to workspace only.
And they do not notice this mistake.
This is giving us problems - and updated documents are lost.
A way to prevent this is to set a file as read-only when it is downloaded to workspace and not checked out.
Many systems work like that, e.g. Documentum
Best Regards
Soren Gylden
