Make provision to have WTPart and associated CAD & WTDocument report
Currently, there is no OOTB comprehensive report available that can list all associated CAD and WTDocuments to the Parts and allow it's export and vice versa. Checking the association in Windchill takes a lot of man-hours which needs to be done manually one by one or using the Structure tab. In the structure tab, the association can be seen in bulk but of only BOM and its child components.
It would be great if PTC provides the custom report that can do below -
  1. When Parts are searched report needs to fetch all its associated CAD Documents and WTDocuments.
  2. Below Association types should be considered for report generation
  • Described By Documents
  • Reference Documents
  • CAD/Dynamic Documents
  1. When  CAD Documents are searched report needs to fetch all its associated WTParts and WTDocuments.
  • Associated Parts
  • References (Documents or parts that the selected object references.)
  • Referenced By (Documents or parts that reference the object)
  • Source and Image
1 Comment
JeffZemsky
This is something we are looking to improve in the future for our BOM reporting.
As a work for this - today you can use the Change Baseline  Report (its exposed at the Site level -> Preferences -> Change -> Change Baseline Report Display
It will give you a structure list of Parts, Documents and CAD (as well as Changes that released or that the items are on) that you can also do an Export List to File from
