Similar to the Assignee and Reviewer selection in the Change Task Create/Edit Wizards.
In many cases, Change Management Workflow participation varies and therefore resolving Roles from a Context Team does not provide sufficient flexibility. It's easy enough to add a Workflow Assigned Activity to set up the variable downstream participants (such as commodity based Purchasing Agents) but it feels clunky to finish setting things up in the wizard, submitting and then completing a Task. If you set Notifications on that Activity, then it's Spam to self and if not it can get overlooked and the workflow stalled. This would help make use of the Product -Centric foundation PDMLink more flexible and prrovide a streamlined user experience, especially for SMB's and Org's where "Product" solutions get deployed across multiple Projects
