Manage collector preferences when the WT.Part is shared to a project context
Problem:
If an article is shared into a project context, some WT.Parts and/or related documents in the product structure will be excluded from sharing the data. When the project is snychronised by scheduled jobs overrnight, the initial preferences are ignored and the all the WT.Parts and related documents in the product structure will be shared.
Possible solution: Share only the WT.Objects which were initially shared or Snychronise the WT.Objects with the collector preference as "No dependents".
Please refer the attached file for a better explanation. Thank you.
2 Comments
sgoletz
6-Contributor
Thank you for sharing this windchill ProjectLink idea.
Especially in a project where a huge amount of objects is shared, the auto-synchronization is mandatory to manage the content. Unfortunately, currently the behavior of the auto-synchronization cannot be influenced and all related objects are shared to the projects by default.
lwahl
Good idea, absolutly necessary
