We use SWLink (Windchill Integration for Embedded Software, also called IES) to map Integrity objects with Windchill. This interface is powerfull for Defects, allowing mapping of 17 attributes including hyperlink which permits to open from Windchill the Defect in Integrity Web client.
For Software Document and Software Configuration Data, the mapping is restrained to the name, and the content of the object is imported, no hyperlink as for Defect. We will need mode data mapped :
- Number
- Created by
- Created on
- LifeCycle State
- Hyperlink
