Mass change possible, but not mass check in
After a mass changes of several items, it is not possible to select all the items and to a mass check-in. You have to go to all the parts and check them in one by one. Philips preUAT #184. Windchill 10.2 M030
Mass Check-in, Checkout and Undo Check out is supported for Parts and Documents (no content change) in Change tables, Folders and Search in 10.2 M030
2 Comments
JeffZemsky
Ray,
If you are talking about Parts, it is Mass Check-In is supported in 10.2 M030 from the Change Tables, Folders and Search.  CAD Documents are not supported for Mass Check-in from those tables as its a Workspace side action.  You can however do the Mass Checkin of the CAD docs from the Workspace.
JeffZemsky
Status changed to: Current Functionality
Mass Check In is available with Windchill 10.2 M030.  This is supported for Parts and Documents.  CAD Check In is still handled via workspace.  When working with Documents if updates to content need to be done, they are not handled via multi-object Check In.
