Merge Uses functionality in MAPSB and Part Structure Browser
It would be very useful to have a 'Merge Uses' function in both the MAPSB and the Part Structure Browser.
Function should work as the opposite of the 'Split Usage' function in the MAPSB
2 Comments
ghansen
11-Garnet
In MAPSB: You can use #cut and then #Merge Usage After Cut to merge together again split items.
Do like this:
1: Mark one item line and RMB #Cut
2: Mark the other item line and RMB #Merge Usage After Cut
Function works as the opposite of the 'Split Usage' function in the MAPSB ....
olivierlp
Community Manager
Status changed to: Archived
