Checking in CAD models contained into a configurable product or module, all the coices assigned to sub components are transfered to the relative wt part.
But, if there is a wt part with two or more EPM document associated (eg.owner and image) is impossible to set different coices to theese CAD document because windchill is unable to merge the coices in a single WT part.
This could be useful if you have to represent two different instances for the same geometry (eg. different tensions on the same belt) and choose the correct representation in a configurable product managing a single wtpart.
