Is possible send a message to the user that required the promotion, if this is rejected from the approver?
There is a "Comment box" for the approver, where I can insert the reason for the refusal.
Is important that this comment will be delivered to the user to inform him about what to do.
Is good if this comment will be insert into the mail that is send if the promotion is rejected...
