Modify Check-Out Behaviors for Multi-Object Attributes
We recently ran into this issue with editing a Sourcing Configuration multi-object via the Line Sheet.
When a user enables the "Edit" function for a Multi-Object that is on a Line Sheet, a new window or tab will pop-up where the MOA table can be edited. If a user clicks the "Done" button when they are finished editing, the pop-up closes and is able to be edited by other users just fine. But, if a user closes the editing window without clicking the "Done" button, the window closes (even though the MOA attribute is still checked out to the editor) just the same (from a UI perspective) as if the "Done" button has been clicked. This often causes the user to not be aware they still have the MOA checked out and end up locking out other users from editing.
It would be helpful if, in this scenario, the system would prompt the user to confirm if they wished to check the MOA back in and save the changes or to discard the changes, much the same as the BOM or Measurement Sets behave when the user attempts to close the editor.
In addition, should an MOA remain checked out, it would be helpful if MOA's showed up in the user's "My Work" section under checked-out documents so that they could have visibility to what they have checked out.
4 Comments
KrishnaMantrava
6-Contributor
did you already try the "Manage Locks" link ?
ssherowski
6-Contributor
Thanks Krishna. I hadn't thought of that (thank you for the callout). This certainly would assist us when something needs unlocked, however this is only available to administrators, correct? Our general user base typically would not have access to this page. I think ideally what we are trying to solve for is the users' ability to monitor and prevent these locks from ocurring before they happen.
KrishnaMantrava
6-Contributor
yes, right now it's only available for admins and not for general user base.
PTCModerator
Emeritus
Status changed to: Archived
