When using the "Save as" funtionallity, the newly created objects inherit the values for all custom made attrubutes.
Often these values has to be modified anyway, so the object has to be check out/modified/checked in after the "Save as"
Having the ability to modify the values in the "Save as" wizard would reduce the work of copying an object.
