If you have WTDocuments with same filename in primary content and try to download them with the action "Download Documents To Comperssed File" you will get only one file in archive.
For example:
1. I have 2 WTDocuments. Primary content of this documents different, but have the same filename.
2.If i try to download this 2 files with action "Download Documents To Comperssed File" i will get only 1 file in archive
PTC said that so works by default.
I think if there is found a few files with the same filename Windchill must download all files. If Windchill meets several files with the same filename, he must add something to their name.
For example above, i could get in archive:
1.docx
1(1).docx
