Today, CATIA Model tree status are only based on out of date information of the active workspace. So if a config spec is set on the workspace, the status in the model tree can display a out of date status therefore all the objects fit to the workspace config spec.
We would like CATIA Model Tree Status to be based on the out of date with workspace configuration status. The result will always be correct :
If there is no config spec on workspace, status are the same between out of date and out of date with workspace configuration and if a config spec is set, we will see the information we need because we have just set the config spec.
