Multiple sheet DXF/DWG-Output for Creo drawings is currently only available for user-driven export (All sheets as a paper space). On CAD-Workers for the Windchill Visualization Service (WVS) multiple sheet drawings are currently exported in single files for each sheet!
Customers need an option to confgure the behavior for multiple sheets on the CAD-Worker side,
for example by:
