For example: two document subtypes. They are using WTDocumentDependencyLink relationship. The mapping format is like this :
describes@wt.doc.WTDocumentDependencyLink~describedBy^com.ptc.layoutrequest~division
Then check out/check in layoutrequest subtype object then alias attribute will show all iteration object's IBA value splited by comma.
Customer hope it can just show the latest iteration object's IBA value.
