As far only in NX File > New does integrate the Windchill UI.
But user even frequently use NX - Assemblies --> Components --> Create new Parent or Create New Component and only get the standard NX dialog.
Optimal: It provides also Windchill Create Dialog for EPM -
Minima required: Windchill provides for file name the autonumbering introduced in Windchill.
Optimal was raised in TS Call: https://support.ptc.com/apps/case_logger_viewer/auth/ssl/case=12500541
The minimal solution in https://support.ptc.com/apps/case_logger_viewer/auth/ssl/case=12554693
