Hello all
For various customer projects we urgently need the possibility to take the names of EPM documents and WTParts from an enumerated list.
I know that there is a configuration option (CS168027), but unfortunately this only works with CREATING WTPart / EPMDocument and not WITH RENAME/SAVE AS.
Therefore, it is not usable for the WGM from Creo Elements /direct, for example...
PTC: please add this feature to Windchill's standard.
Thank you very much!
Thomas
