Advanced Search returns older revision of the object for matching criteria. Selecting "Latest" revision in advanced search doesn't help. How to do a search so that it returns results ONLY if criteria matches with the latest revision of the object (document or part)? I opened a case with Technical support (Case# 13408122) but could not get any resolution. PTC Technical Support tried do it using various ways, including a QML report, but was unsuccessful. PTC support also discussed this use case with Tech Lead and found there is no such OOTB way to achieve this requirement. Also refer Article - CS157314.
