A common requirement is to "take a picture" of a BOM to be stored as a configuration. The Part Configuration feature is close, but are depending of trace code settings. Baseline is to hard to use, because it will not capture the structure it´s self so you need to configure the structure-filter to get the captured structure.
The main features shall be:
- Capture a product structure with one click (as Part Configuration)
- Captured configuration shall show the static product structure (as Part Configuration)
- No dependencies to trace code (as baseline)
- Compare Captured configuration with any BOM configuration (as baseline)
- Repopulate Captured configuration (as Part Configuration)
- Open Captured configuration in CAD or download to worksppace (as baseline)
- Visualization shall support Captured configuration (as baseline and Part Configuration)
- Link documents to a Captured configuration as verification reports etc. (as Part Instances)
- Share a Captured configuration to ProjectLink
- Support Captured configuration to be exported by ERP Connector.
