Need the ability to constrain the types of CT's allowed based on the CN type
At Boston Scientific, we need the ability to constrain the types of CT's allowed based on the CN type.
We have multiple Change Task types and Change Notice Types, we need to be able to constrain which type of CT's can be used in which types of CNs
• CN types = Full Track, Fast Track, Document procedure change process
• CT types = General CT, Doc CT, Sales BOM, Localization, Fast track CT, Doc Procedure CT Need the ability to assign who can do the work including constraining the resources to a specified group.  Also need to limit the types of objects that can be associated to each CT type to the object types in which those groups are trained (ie. manufacturing instructions and routings)
This was introduced with Windchill 11.0 M010.
4 Comments
JeffZemsky
This is under development for the release after Windchill 11.0 F000.  You will be able to define which Change Task types are applicable to which Change Notice Types as well as define - Required Change Tasks and Cardinality - eg (Simple Change Notice can only have one Simple Change Task)
JeffZemsky
This is supported in Windchill 11.0 M010 with the addition of supporting Change Implementation Plan Associations to the types of Change Associations one can create.  With this an admin can specify which CT type(s) are allowed for which CN type(s).  Additionally the Cardinality can be set to 1:many or 1:1.  The following is an example of creating a Rule like this:
STEVEG
This is fantastic.
JeffZemsky
Status changed to: Current Functionality
