Need to get a more precise error message when trying to add the same WTPart multiple time in a BOM
If you try to add an already existing WTpart in a BOM, you will get an error message which is fine.
Problem is that if you are adding multiple WTPart at the same time, you will get an error message saying that a WTPart already exists, but you will not know which one.
That should be nice to get the number of the already existing WTPart.
2 Comments
ChristopherLewi
9-Granite
Can you confirm whether 10.2 is improving the way errors such as this are handled. I think i saw some improvements on this function in a ptclive presentation.
PTCModerator
Emeritus
Status changed to: Archived
