A new association needs to be added for EPMDocuments and wtParts. This one needs to allow for driving structure but allow for changes in quantity and to use the unit of measure associated with the wtPart or allow for it to be changed in the BOM. Currently you are only allowed for each and whole numbers. I need to be able to have items that are in feet with decimals. Since to change them, you cannot have any association between the CAD and the PART, they do not line up on the BOM compare.
An example would be a piece of insulation. It is in the CAD but drawn to length. If the CAD is tied to the Part then the quantity is 1 each in the Windchill BOM. What is needed, is for it to be in the Windchill BOM as the length, like 1.75 feet.
It needs to work like an Image association in that it needs to allow for multiple CAD to one Part. In the example above, we will have a different length or shape of the insulation in different assemblies but the same part number.
