New Yellow Confirmation Bar
Salut,
because we cannot disable this annoying bar at all would be nice at least to reduce banner size and position to avoid hiding functions bellow. My suggestions is this:
19 Comments
TomU
Emerald II
Not sure if you are aware, but you can shorten both the amount of time before it starts to fade out as well as the duration of the fade.
https://www.ptc.com/en/support/article?n=CS46987
I wonder if instead of changing the shape the bar could be configured such that moving the mouse over it would make it instantly disappear.  This would keep it from blocking access to the stuff underneath without having to play games with it's size and shape.  I wouldn't be opposed to using longer display times if I didn't have to click the "x" to get rid of it quickly.
PetrP
Alexandrite
I know that. Set up fade out time from 3s to 1s already but anytime you move cursor over the fading banner it appears again which is superannoying.
TravisR
Visitor
The bar should be at the bottom of the page or somewhere where you can dismiss easily. The only nice feature of this is if you are creating an object, it has the link to the newly created object - but outside of that it is super annoying as stated by PeterP!!
bmr
Peridot
Peridot
When the bar is showed the following work must not be affected. So no navigation or recent menu needs to be accessed right away.
From my side it also could be a popup (not a new page, just an overlay) in the page which the user can place where he want it to have. This info will disappear as soon he navigates away.
tmenadue
Regular Member
It would be nice if it could be set up as a preference to turn on or off...even better as a user preference. But, if that really is not within PTC's plans, then I agree it needs to be moved, resized, or anything else as long as it doesn't hide functional areas of the screen.
BenLoosli
Sapphire II
I like the pop-up window idea with a fade out and automatically removal after X seconds, placed in the middle of the screen.
Doesn't the yellow bar have a close (X) in the upper right corner?
JamesAvis
Amethyst
I wait patiently for it to go away, then, when it is no longer visible, I move the mouse to get at what it was blocking, and it reappears because, mathematically, it wasn't completely gone.  Very annoying!  I'm going to look into shortening the fade time, as suggested.  Thanks!
a preference to turn on or off will be great.
at least disable this annoying fade out.
Mayur
Pearl
Like the fade timing, the position of the message box can be customized in Windchill. Please refer below :
Confirmation Message Yellow BarConfirmation Message Yellow Bar
Here is a piece of *sample* code for your reference which can be updated in the Windchill\codebase\netmarkets\javascript\util\jsfrags\messaging\messaging.jsfrag file. (Tested on Windchill 11.1 and FireFox browser)
 Note:
  • Modify the X and Y values for the position of the box.
  • Modify the "msgWindow.height" and "msgWindow.width" to change the box width. Highlighted values are correspond to the box position in above screenshot.
PTC.messaging.msgWindow = new Ext.Window( {
cls: 'inlineWindow',
x:700,
y:0,
draggable: false,
resizable: true, //comes in very handy
title: 'Mayurs Windchill',
shadow: false,
header: false,
closable: true,
bodyStyle:"padding:0px 0px 6px 0px;background:#dafcbd;", //changed the yellow background color
initCenter : false,
focus: Ext.emptyFn // no need to allow this to get focus, 2099943
var msgWindow = PTC.messaging.msgWindow;
msgWindow.height=110;
msgWindow.width= 410;
This is just an example which works when browser is 100% maximized. However, you can add additional generic javascript code to get the browser and screen sizes and then have the box position updated relatively.
Hope this helps!
bmr
Peridot
Peridot
@Mayur your made my day! Love it Smiley LOL
BenPerry
Amethyst
 @Mayur,
The same doesn't seem to work for me in Windchill 10.2.  Is it possible to do the same in 10.2 with some modifications?
Mayur
Pearl
@BenPerry,
Hi Ben,
I was able to get it to work in 10.2 server as well. Below is the code for showInlineMessage() function from Windchill\codebase\netmarkets\javascript\util\jsfrags\messaging\messaging.jsfrag file in 10.2 server :
                                                x:700,
                                                y:0,
                                                height:110,
                                                width: 410,
                                                draggable: false,
                                                resizable: true,
                                                title: 'Windchill 10.2 M030',
                                                shadow: false,
                                                header: false,
                                                closable: true,
Works in 10.2
The general steps remain the same:
1. Edit the messaging.jsfrag file
2. Run the 'ant -f bin\jsfrag_combine.xml' command
3. Restart Windchill
Hope it helps.
munruh
Garnet
 @Mayur,
I implemented your solution about a month ago and everybody here loves it.  Thanks for the information!
PetrP
Alexandrite
Works like a charm on WCH 10.2. Well done Mayur! Think PTC should implement message layout as an option and let users pick from "banner" (default) or "window" (shrinked).
Mayur
Pearl
@munruh,@PetrP, I am glad that you like it. Feel free to leave 'kudos' 😛
PTCModerator
Emeritus
jgoncalves
Granite
I've made some improvements to look like this.
  • Is is centered
  • close button is improved
            //x:0,  // left offset -  disabled. margin will set this value.
            y:0,    // top offset
            draggable: false,
            resizable: true,                                             // TCA: make this windows resisable
            title: 'Windchill 11.0 - Custom messaging.jsfrag',           // TCA: set the title. can be empty
            shadow: false,
            header: false,
            closable: true,                                              // TCA: add button to right side of title
            bodyStyle:"padding:0px 0px 0px 0px; background:#dafcbd; margin: 0 auto; ",     // TCA: set backgound color and margin auto center
    msgWindow.height=120;                                                 // TCA: set height size
    msgWindow.width=500;                                                  // TCA: set witdh size
    TCA: this button is redundant and ugly (semi-hidden). It is now disable
    var closeButton = new Ext.BoxComponent({
        autoEl: {
            tag: 'div',
            //cls: 'x-tool x-tool-close',
            html: ' '
    msgWindow.add(closeButton);
damir
Regular Member
Hi all,
Does anybody knows how to invoke that script from java code?
Thanks in advance.
jgoncalves
Granite
@damir , The ant script is executed from windchill shell. This does not work for you.
Since I cannot edit my previous post, my updated and more correct code (messaging.jsfrag) is
            y:0,    // top offset
            draggable: false,
            shadow: false,
            header: false,
            closable: false,                                             // TCA: add button to right side of title
