Number-field missing in "Replace" dialog (Save as)
When using the "Replace" functionality during a "Save as" in the workspace - it is only possible to search for replacements by "Name" (Commonname).
Problem:
  • Name is not unique
  • To many objects are listed (example "Bolt")
Here it should be possible to search also for "Number"
6 Comments
Granite
Good sugesstion.
Many customers also use the filename as identifier (which is also unique). Therefore I would recommend to add not only a search function for number, but also for filename.
Aquamarine
Good suggestion to a good idea.  Without a unique identifier this collector functionality (such as number or file name) is almost useless.
Amethyst
Daniel Kremers‌, how did you get that replace functionality? I cannot see that button in our Windchill 10.2. Is it a customization or can it be activated with some preference?
Visitor
Hello Jari Elomaa‌!
It is a Preference (Site):
Save As > ...Replace...
Amethyst
Thanks Daniel,
I'm only a product admin so that's why I'm not seeing it. I'll contact our site admin and ask, if this could be enabled for us.
Community Manager
Status changed to: Archived
