Number of decimals displayed for real type attribute in Windchill PDMLink
We need a way to control maximum number of decimal values for real type attributes in Windchill. When real type values are published from Creo, they have14 decimals, which is confusing and mess up the UI.
I propose that you should be able to set a limitation of maximum decimals in the type-manager per real number attribute.
31 Comments
Durga
Hi All,
Could anyone help me if what is the work around so that it displays only 2 digits after decimal.
Thanks in advance.
RobertH
As far as I know there is no real workaround. The only thing you could do is limit the number of decimals of the parameter in Creo that is used for this attribute.
Durga
RobertH
Like I sayd, it's only possible to solve it in Creo 🙂 . Also add the units to the attibute causes that you are unable to checkin old data because Windchill then misses the unit and doesn't accept it until you add the units to Creo.
ggalli
6-Contributor
I hope that PTC include this feature in next release of Windchill !!!
BenLoosli
23-Emerald I
Do NOT hold your breath waiting for it, ggalli.
