Currently there is no out of the box (OOTB) functionality to automatically publish the release date captured in Windchill (date in which an object moves to the released life cycle state) into a Creo Parameter on the Drawing Title Block.
There are ways to do this with customization inside an expression robot on a workflow template and then messing with the Publisher setup but this seems like a common request that should be handled OOTB similar to how Revision is handled with the "&ptc_wm_revision" syntax.
I also understand that not every customer uses the life cycle state "Released," so there should be a property setting or a preference to define what the "final" life cycle state is which would trigger the date capture.
