Open an Assembly in As Stored configuration without adding it to the workspace first.
Open an Assembly in As Stored configuration directly from Windchill without adding it to the workspace first.
Open in Application command always opens the assembly in Latest Configuration even if the preference Workspace > Add to Workspace and Check Out > Set Configuration for Add to Workspace is set to AS_STORED.
3 Comments
MikeLockwood
22-Sapphire I
By default, publishing is As Stored, so viewing any parent item (e.g. Assembly or Drawing) views it As Stored - requiring only a browser.
hhagedorn
6-Contributor
@MikeLockwood
Unfortunately I can't do anything with this statement, because I can't load the CAD model via the browser when opening it. You need the WGM and the CAD models are only loaded in the "as latest" version.
JenniferPierron
Status changed to: Under Consideration
