Open in Creo action from a history tab should chose "As Stored" by default
When you want to open a previous version of a drawing or assembly from the History tab, it would be useful that the “Open in Creo” action be set to “As Stored” by default.
Avoid adding to WS and changing to "As stored"
2 Comments
PTCModerator
Emeritus
vgh
3-Visitor
3-Visitor
How is the status of this topic? Are there any planned activities?
We would also need this, since transformation from MM is very challenging with this different and not changeable behavior.
Also, it would be really necessary to set this as a property, see
https://www.ptc.com/en/support/article/CS311609?&language=en&posno=1&q=cs311609&source=search.
