Open multiple Inventor files in one step
Enable opening multiple Inventor files in one step
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
I am a member of terra infrastructure GmbH (provider in civil engineering, port construction and special civil engineering). I am a key user in engineering responsible for the trench shoring and Windchill customization for the MCAD user. My stakeholders are the machine builders and IT data management.
2. What version of Windchill are you currently using?
11.1
3. Describe the problem you want to solve. Please include detailed documentation such as screenshots, images or videos.
The Inventor user would like to have the same ability as the CREO user to open multiple CAD files in one step from the workspace/common space as described in the Windchill Help Center
https://support.ptc.com/help/windchill/whc/whc_en/index.html#page/Windchill_Help_Center%2FWWGMInvPDMActionsOpenfromWC.html%23
Open from Windchill
This action allows you to select a CAD object from the active workspace or from the common area of the registered Windchill server and open it in your active Inventor design session. The Open from Windchill action is available from the Windchill menu in Inventor.
If you select Open from Windchill, the Windchill window and the Open from Windchill window open. From here you can browse for the file you want to open in Inventor. If you need to open multiple CAD documents, you can do so with a single Open from Windchill action.
4. What is the use case for your organization?
Our designers often need to open different drawings of a CAD document structure and in the past (before migrating to Windchill) did this in one step. Therefore they demand to have the same possibility in Windchill.
5. What commercial value would your proposal bring to your company?
Improved productivity and smoother migration to Windchill
Translated by Olivier Le Pord using Google Translate on Dec 15, 2022
Title:
Öeffnen mehrerer Inventor-Dateien in einem Schritt
Aktivieren Sie das Öffnen mehrerer Inventor-Dateien in einem Schritt
  1. Beschreiben Sie Ihr Umfeld: Was ist Ihre Branche? Was ist Ihre Rolle in Ihrer Organisation? Beschreiben Sie Ihre Stakeholder.
    Ich bin Mitglied der terra infrastructure GmbH (Anbieter im Tief-, Hafen- und Spezialtiefbau). Ich bin Key User in der Konstruktion für den Grabenverbau und für die Windchill-Anpassung für den MCAD-Benutzer verantwortlich. Meine Stakeholder sind die Maschinenbauer und das IT Data Management.
    2. Welche Version von Windchill verwenden Sie derzeit?
    11.1
    3. Beschreiben Sie das Problem, das Sie lösen möchten. Bitte fügen Sie eine ausführliche Dokumentation wie Screenshots, Bilder oder Videos bei.
    Der Inventor-Benutzer möchte die gleiche Möglichkeit wie der CREO-Benutzer haben, mehrere CAD-Dateien in einem Schritt aus dem Workspace/Common Space zu öffnen, wie im Windchill Help Center beschrieben
Aus Windchill öffnen
Mit dieser Aktion können Sie ein CAD-Objekt aus dem aktiven Arbeitsbereich oder aus dem gemeinsamen Bereich des registrierten Windchill Servers auswählen und es in Ihrer aktiven Inventor -Konstruktionssitzung öffnen. Die Aktion Aus Windchill öffnen ist im Windchill Menü in Inventor verfügbar .
Wenn Sie Aus Windchill öffnen auswählen  , werden das  Windchill  Fenster und das Fenster  Aus Windchill  öffnen geöffnet. Von hier aus können Sie nach der Datei suchen, die Sie in Inventor öffnen möchten  . Wenn Sie mehrere CAD-Dokumente öffnen müssen, können Sie dies mit einer einzigen   Aktion „ Aus Windchill öffnen“ tun.
4. Was ist der Anwendungsfall für Ihre Organisation?
Unsere Konstrukteure müssen oft verschiedene Zeichnungen einer CAD-Dokumentstruktur öffnen und haben dies in der Vergangenheit (vor der Migration zu Windchill) in einem Schritt getan. Daher fordern sie, die gleiche Möglichkeit in Windchill zu haben.
5. Welchen geschäftlichen Wert würde Ihr Vorschlag für Ihr Unternehmen darstellen?
Verbesserte Produktivität und reibungslosere Migration zu Windchill
1 Comment
olivierlp
Community Manager
Thank you @AD_10399672 for your idea. Based on the information you provided (and after translation 😉), we are acknowledging it as the Community management team. This is not a commitment from the Product team. Other users may comment and vote your idea up.
