Open up vault folders
The system should remove the Read Only value from vault folders based on a threshold value. If the wt.fv.fvFileThreshold value is met then the folder is set to read only. Why not unset read only if the value goes below wt.fv.fvFileThreshold value.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
