Opening a Part Configuration Struct. in CreoView should reflect "overridden" PartVersions on occ lvl
In a (Full) Part Configuration, you can switch to "Show Occurrences" Display. With the "Override Part Version" functionality, you can exchange singular Part Occurrence Versions. This is used e.g. to document that in a specific "as maintained" configuration, one of many "same" part occurrences has been replaced by a service technician to the latest version of this part. If you "Load the Structure in CreoView", this ignores the overridden occurrences. Thus it is not possible to visualize exactly the "as maintained" part configuration.
It would be very helpful if CreoView would reflect the exact part versions on occurrence level.
1 Comment
Peridot
Status changed to: No Plans to Implement
We should be supporting this in Product Instance.  Product Configuration is meant to hold information for creating or updating Product Instances which is where the As-Maintained/As-Built information would be seen.
