PP: Re-pos of product using operated on not follow to Creo View on the following op
Process Plan: If you want re-positioning of product during playback you can use "operated on".
This re-position follows thru the playback until another "operated on" re-position the product again.
The GAP here is if you are in playback, the positioning of product using "operated on" not follow to Creo View on the following operations as expected. See attached PowerPoint.
Creo View open dynamic structure in playback is not showing the same positions as visualization tab with dynamic structure is showing.
For users this is a bug but for PTC this is an enhancement so therefore we need to follow the administration and create this Product Idea so PTC could file an SPR to it.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
