PTC Windchill status Tab ( Solid Works )
we're working with WNC 12.0.2 & Solidworks 2021.
we use the wgm in order to managed solidworks data inside windchill . The newly added "PTC Windchill status Tab ( Solid Works )" is an excellent enhancement which improves usability and make integration easier (user wise).
it would be very beneficial to add the following capabilities to the tab:
- having automatic highlight in both directions - selection an item in tab will highlight it in graphic area and selecting and items in screen will highlight it in Tab ( only once tab is expended).
- adding "Open" to RMB when selecting items in tab.
- adding the possibility to search in tab.
- adding additional rows.
2 Comments
olivierlp
Community Manager
Status changed to: Clarification Needed
Thank you for publishing your idea. We need more information as specified in the form you saw in the submission process. (Questions below). The more details and context you give, the better.
Please let us know within the next two weeks.
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What product & version are you currently running?
3. Describe the problem you are trying to solve (not so much the solution you have in mind). Please include detailed documentation such as screenshots, images or video. I recommend to be as detailed as possible on this. This is the most useful from a product management perspective.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
olivierlp
Community Manager
Status changed to: Archived
We are following up on our request for additional information on your idea. In the absence of further comments from you, we are archiving your idea. You still have the option to post a new idea with all the details required.
Thank you.
