Parts and drawings don't correspond to the correct version / traceability management not possible
0 Kudos
1. 描述你的環境:你的行業是什麼?您在組織中的角色是什麼?描述你的利益相關者。
工具機,副工程師
2. What version of Windchill are you currently running?
11.0 M030-CPS17
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
系統上2D圖面版本對不上3D圖面的版本,他永遠只顯示他相關聯3D的最新版,反之也會有相同情形,在未來在溯源時,對應不上對的版本,無法溯源管理。
4. What is the use case for your organization?
Case: C16233047
5. What business value would your suggestion represent for your organization?
下游單位在系統上的溯源管理
(Original idea title: 零件與圖面對應不上對的版本,無法溯源管理。)
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Machine tool, assistant engineer
2. What product & version are you currently running?
11.0 M030-CPS17
The 2D drawing version on the system does not match the 3D drawing version, it will always only display the latest version of its associated 3D, and vice versa, the same situation will happen. In the future, when the source is traced, it will not correspond to the correct version, and traceability management will not be possible.
Case: C16233047
Traceability management of downstream units on the system
Translated with Google translate by @olivierlp on Feb. 14, 2022
3 Comments
olivierlp
Community Manager
olivierlp
Community Manager
Hello AY_8858111 and welcome to the Community.
Thank you for your idea and the information you provided.
olivierlp
Community Manager
Status changed to: Archived
