After initialized classification tree, it should allow user add/update classification nodes in batch by loading csv file.
The following is usecase from customer:
If we have an n number of nodes and related attributes and constraints that is need to be added to classification structure, doing these things manually is consuming more time, what we exactly need is loading all these nodes and attributes at a time by updating these values in excel or csv.
This will reduce more efforts from admin side.
