I would like the ability to pass representations from describing WTDocuments to the WTPart they are linked to.
The main use case is for library parts and supplies that do not have geometry, oil and other fluids, paint, grease, thread lock, adhesive etc are good examples. From a WTPart perspective these typically have a UOM other than each, so it is not possible to accurately drive structure from CAD so there is no CAD to associate, bulk items would be a waste of time. While the fluids listed before are the most engineering related examples. We have a WTPart for everything we buy in the organisation, so things like safety equipment (gloves, boots, goggles, etc) also have a WTPart.
Typically to help sourcing the WTPart is described by a WTDocument that contains an image file showing a picture or a spec sheet for the item. It would be useful and more efficient to be able to pass representations for the WTDocument to the WTPart to save supply chain staff having to navigate to the describing document to view the content/representation.
