Ability to filter parts in case the same parts are added in multiple paths
Use case: a user wants to display only the parts in multiple assemblies using Path Filter on PSB. If the same parts are added to different paths, a user cannot filter one and display the other.
Path Filter on PSB: selecting the parts to display
If selecting "PARTA" under "TOP_ASSY" as well as "PARTB" and "PARTC" under "SUB_ASSY1", the path filter result is:
"PARTA" under "TOP_ASSY" is displayed (this is expected). But "PARTA" under "SUB_ASSY1" is also displayed (this is not expected).
In this use case, a user does not want to display "PARTA" under "SUB_ASSY1", but the other "PARTA" in another path was selected, so this one is also displayed.
In MAPSB, the path filter can filter out "PARTA" under "SUB_ASSY1". We suggest Path Filter in PSB should work in the same way as MAPSB.
