Personnalize Action Item in ProjectLlink
0 Kudos
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Life Science Industries.
Site/Business Admin - Development/implementation of PLM solution
About 100 end users. Several hundred of projects on the system.
2. What version of Windchill are you currently running?
11.0 M030, update to 12.2 scheduled this year
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
Personalize existing attribute of Action Item (wt.meeting.actionitem.DiscreteActionItem): rename attribute, adding constraint as legal value list, add new attribute.
The import/export tool with Excel should reflect the actual attributes(eg : display name) of the action item.
Subtyping the action item to be used with with different subtype of project.
4. What is the use case for your organization?
Adapt action item to the project need as other wt object in Windchill.
Specific action plan according to the project.
5. What business value would your suggestion represent for your organization?
Track action plan for multiple customer projects related with accurate/dedicated attributes depending of project subtype.
2 Comments
olivierlp
Community Manager
Thank you for your idea and the information provided.
olivierlp
Community Manager
Status changed to: Archived
