Possibility to change email form mask in Windchill notifications - display sender with "Name, First name" instead of email address
When an email (for example a notification email) is sent by a windchill system on the behalf of a user the sender is displayed as : john.doe@xxxxx.xxx
Is it possible to have the following displayed sender : “Doe, john” ?
We would like to modify the email form mask to change the sender ( <ie:param name="FROM" data="" default="<%=DEFAULT_FROM%>"/> ) by Name and First name.
It will be especially usefull to filter/sort/organize messages in a mailbox when usual sender format is "Name, First name"
This is an example of the current result :
It is not really practical if you try to sort by "from" column, that's why it would be interesting to be able to parametrize the way Windchill define the "from" mask.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
